Internal auxiliary hydraulic pump for MF 240
   / Internal auxiliary hydraulic pump for MF 240 #1
skiroy56
Cumberland, Va.
Kubota M7060HD8, John Deere 420C,
I have a MF 240 without auxiliary hydraulics.
I want to add an internal auxiliary hydraulic pump to be able to add a front end loader.
Does anyone know the necessary parts required to make this alteration.
Seems like everyone wants to suggest a crankshaft mounted pump or a PTO pump or the MF dealers want me to buy a new tractor.
My research has led me to believe that an internal pump is available but not sure the unit needed.
Any help would be greatly appreciated.
Laurence
   / Internal auxiliary hydraulic pump for MF 240 #2
You could install a fan belt pump.
I have a 3 GPM fan belt pump with a pressure of 3000 psi, and it does a very creditable job.
My internal pump is a 4 GPM and I have been told that it will be painfully slow.
I just got off of the phone with a person at Koyker in SD and was told I would have an open system and could not explain to me what that meant and would not transfer me to Tech Support. No help so far. I really want an internal pump so I have nothing external.
I realize that the fan belt pump will work but was wanting something less obtrusive.
Thanks for the input.
Laurence
   / Internal auxiliary hydraulic pump for MF 240 #4
Open center hyd systems is usually powered by a gear pump and pumps continuously through all valves in series.
You can add an open center valve in the series path, but must have PB, which is power beyond/carry over pump flow.
The fan belt pump would look no different than your generator or alternator.
Can you install a larger pump?
More GPM's mean faster operation.
   / Internal auxiliary hydraulic pump for MF 240 #5
My Mitsubishi only had about 3.5 gpm and that loader was painfully slow.
By chance I acquired a 5 gpm and made a bracket to mount it up front, used the Mitsubishi adapter that fitted the crank pulley and installed a U-joint to couple it up.
Since my loader had a reservoir in one of the posts I plumbed that to the valves.
I installed a high pressure filter (aviation surplus) between the pump and valves.
Sweet installation, makes the tractor think it is a skid steer.
Now I need to install my power steering. Just need to make a frame bracket as I have the steering valve and cylinder plus most hoses.
While I could jamb fit my steering to the steering valve I'm reluctant to do so as the splines don't match and I don't want to damage it (just in case)
   / Internal auxiliary hydraulic pump for MF 240 #6
Laurence
According to tractor data.com the pump flow on a 240 is 9.5 gallons per minute. Capacity of 8.6 gallons. Also states it has two valves.
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
2023 Evolution Classic 4 Pro 48V Golf Cart (A53002)
2023 Evolution...
