Iron Horse (Jinma 254) Brake question.
   / Iron Horse (Jinma 254) Brake question. #1
jgl1962
Bronze Member
Barton, NY
Hey,
The left brake has been locked (I assume frozen as it's been 10-15 overnights) the last couple times I went to use the tractor. Even rocking wouldn't let it go the last time but a few minutes with a propane torch on the housing and they came loose.
While under the I noticed bolts that are positioned like drains at the bottom of each brake chamber.
Are they drains for water? or is there supposed to be fluid in those chambers..nothing came out when I removed them.
Jim
Tommy,
Thanks .I was hoping there wasn't supposed to be oil up in there. I will shoot them up with WD 40 next time I use it and see if they stay freed up.
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2008 Jeep Compass (A50120)
2008 Jeep Compass...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
