DJP
HI: anyone : I have a Mahindra 4500 2WD 6-foot HANDY BUSH HOG. After 15 to 20 min's cutting with my bush hog cutter, I notice on my TEMP cage the Hand move over to the center of the cage reading. It has a F in the center. Is this a sign that my tractor is running/getting hot? Is this normal. Where do I need to check to be sure I have enough oil or fluid in the right places, that may be causing this. MY bush hog cuts as good or lower than a push lawn mower. The two bush hog blades cuts low. Could the low cutting be causing my temp reading to go to the center F position. WHAT/WHERE could I check???s
