Is There a 12 Volt Chainsaw ?
   / Is There a 12 Volt Chainsaw ? #1
MrJimi
Elite Member, Rest in Peace
NorthEast, Florida
Case 1845 C Skid steer
That could be used on a tall boom pole ? That would be great. I'm thinking about getting a 12 volt inverter and use an electric el-cheapo saw, like one of the $60 ones
Jim:)
   / Is There a 12 Volt Chainsaw ? #2
Is there a 12 vold Chainsaw? Why yes! .....and I own it.
About 20 yrs ago a firm made a few of them. I own the first protype and it works quite well. I do not think they are in business any longer.
Mine uses a motor similar to the lift motors on boats, that is according to the guy that rebuilt mine. However it was designed for full time use not just short runs.
I won mine in a new Ford dealership grand opening. I heard about the party on the radio and I was passing through the town, stopped for a break and a snack, salesman wanted me to entry the drawing, the next day he called and said I won a chain saw.
It is a great saw with a 20" blade and I use it when I am camping and around the farm with my tractor for power.
I think there is a market for them.
Curt
   / Is There a 12 Volt Chainsaw ? #3
I got to thinking about your chain saw idea.
Have you considered a hydrolic tree pruner? My father in law used one. It had a 8-10 pole with a fairly heavy lopper shear. He ran it off the tractor hydrolic system.
These are fairly common in the Pacific NW for fruit trees etc.
Curt
Yes, I have and I'm not to crazy about that, my boom pole can be 29 feet tall, thats lots of hose?
I was thinking about a 110 volt saw with an inverter mounted on a spring and a hinge at the top and NOT rigid mounted, I could lower it on a limb and spring would push down gently, I think ?
And I could remove it for limbing and plug other 110 items in the inverter
What cha think
Here is a picture of my boom pole
Jim
   / Is There a 12 Volt Chainsaw ? #5
Makita makes a 12 volt chain saw. In the British market they called it a trimmer/clipper or something like that to avoid being subject to regulations governing "chain saws." Most electric "cordless" chainsaws use 18 volt battery packs. So unlike the Makita, they can't be easily connected to common 13.8 volt automotive-type charging battery maintenance circuits. 18VDC chain saws WILL run on those lower voltage systems but cut at a much slower rate and you'd need to pull their internal battery to avoid that 18VDC verses 13.8 volt conflict. Electric motor designs typically cool by brisk air flow. But if little DC motors designed to run at higher speed are heavily loaded and run slower overheating damage may occur. So both performance and durability issues argue against lower than design-voltage operation.
Some cordless chain saws have VERY short blades. User satisfaction is probably enhanced by discouraging them from undertaking sawing tasks which would quickly exhaust their saw's limited stored power reserves.
Driving 120 volt AC chain saws with inverters is a workable solution. But that introduces AT LEAST one more efficiency dropping step, often two efficiency dropping steps as I'll explain.
Typical low-priced inverters operate well below 90% efficiency and some dip below 80%, converting the rest to waste heat. The most efficient can convert about 94% of input power to output over the most-efficient part of their efficiency curve. Engine electrical systems are typically alternator charged and buffered by a battery sufficiently substantial to spin the engine's starting motor. That starting reserve is enough to sustain most inverter loads during short periods when drawing current exceeds alternator charging capacity.
Consider an extreme case, the tiny Kubota B5100D diesel's 35 watt alternator. Clearly the duty cycle that you could drive a common 560 watt 120 volt electric chain saw with an 85% efficient inverter is very limited. Yes, it will work, but you would need to let the little charging system catch up between saw-running periods. After all, that hypothetical inverter load is (85%/1) x 560 watts = 659 watts. So during sawing, 624 watts (659 - 35 = 624) of that power must come from stored power that little alternator output earlier into the battery at 35 watt charging rate. Making this chain even worse is battery charge/dischage cycle efficiency which is only about 80%. That second inefficiency step increases charge recovery time by another 125%. Taking both inverter inefficiency and battery charging/discharging inefficiency into account, that 560 watt saw load requires 824 watts from the alternator to sustain it. 35 watts/824 watts = a fair 4% duty cycle estimate describing usable sawing time per hour. 96% of the time the little electrical system would be recovering from those high-demand 4% use periods. If you're mowing and once in a while need to cut a branch or 4 inch tree, that duty cycle time is enough to sustain operations. But that low duty cycle time is a "deal breaker" that prevents scheduling a day of sawing.
A large machine with a large alternator probably has such a high duty cycle percentage that you can ignore it. But they can't run 8 hours on a gallon of diesel fuel as my B5100D can. Trade-offs everywhere.
The highest amperage draw electric chain saw of which I know is the 13 amp Milwaukee. It would need a heavy-duty charging system to run it. That little diesel's front or rear PTO could easily drive such a large alternator and a larger inverter making that quiet but powerful Milwaukee chain saw mobile over a large acreage. I can report from my experience with system this that total noise level is less than an electric lawn mower. At diesel's current $4.40/gallon, first estimated fueling-cost rate at high duty cycle use rates is be about $.55/hour. Or you can get out your ear plugs and fire up a howling smoker chain saw.
John
   / Is There a 12 Volt Chainsaw ? #6
The DR people offered a rechargable chain saw in one of their catalogs about a year ago. In their more recent catalog, I don't recall seeing it in there.
If you get an inverter to use a 110 volt saw, carefully check the wattage requirement for the chain saw vs. what the inverter will put out. A lot of the more common inverters are probably too weak to do a chain saw.
Ralph
   / Is There a 12 Volt Chainsaw ? #7
With enough inverter, battery and charging capacity you can surely make it work. :D :D :D
The falling limbs may be a hazard though.:confused:
   / Is There a 12 Volt Chainsaw ? #8
I tape my Dewalt 18 volt Recip saw with a 12" blade onto a long fiberglass pole. I use a 3/16 rope through the trigger to operate. I can limb about 20 feet up. I don't know why that wouldn't work on a boom pole.
2011 Ford F-250 Pickup Truck (A44572)
2011 Ford F-250...
Informational Lot (A46877)
Informational Lot...
2015 Ford Fiesta Sedan (A44572)
2015 Ford Fiesta...
2025 Wolverine ADB-13-1218R Auger Attachment (A47484)
2025 Wolverine...
20Yd Roll-Off Dumpster (A44571)
20Yd Roll-Off...
Timber 83AXH-8 Ax Mulcher (A47484)
Timber 83AXH-8 Ax...
