Is there a forum moderator?
   / Is there a forum moderator? #1
John Echternach
Vermont
2010 kubota bx 2660
Are there forum moderators? Is there a way to contact the webmaster? I have a problem. I cannot do a search on any of the forums because there is a pop up add covering half of the search box.
Does anyone know how to fix this or contact someone who can?
Thank you for your help.
Sincerely, John
   / Is there a forum moderator? #2
Hi John,
Post the name of your browser and someone will help you out.
If you are using firefox then at the top of the browser window select; Tools, options, content. Check "block pop-up windows"
If it is internet explorer then select; Tools, internet options, privacy. Check "Turn on pop-up blocker".
I hope that fixes things.
Tig:
Thank you for your quick response. My "pop up blocker" was checked on so that's not it. Could it be that my monitor screen is an older type (not flat) and does not allow a complete left to right width therefore overlapping the advertisement? Anyway thanks for your efforts.
Sincerely, John
   / Is there a forum moderator? #4
Hold the CTRL key down and press the minus key (-) once or twice. (CTRL + will reverse the change.) Just a guess that your frame layout is messed up by a larger that normal font.
I have seen what you describe, but not recently so I'm drawing a blank. If I do remember anything I'll post it here.
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
