Is there any adjustment for the FEL joy stick on the MT125?
   / Is there any adjustment for the FEL joy stick on the MT125? #1
skikir
Eugene, Oregon
LS MT125
Because my garden is on the side of a hill I put bunch of rail road ties as a retaining wall to keep the dirt level. After years they became a haven for slugs and rodents and I wanted to increase the size of the garden and had to remove the ties. I was able to tuck the end of the ties under the top lip of the bucket and lift it up length wise and put it into the back of the truck. It was awkward and was surprised how well it worked and did not damage the bucket. HOWEVER it was PAINFULLY slow! Just due to the fact it was on the side of hill limited it's cross hill travel and I had to keep the rear wheels down hill from the tractor with a 200 lbs 8 foot long tie sticking out lengthwise from the bucket I had to zig zag back and fourth across the hill to the truck keeping the bucket low across uneven ground. But the biggest pain was manipulating that bucket with that gawd awful joy stick! There is absolutely no tactile feed back! There is about 5 inches of travel of the joy stick from center to full left and to full right and half that travel has no response. The same for up and down. Then when you get some hydrolic response it's like full speed. You're always hunting for that response point. And you're hand can't feel it when it starts to move. The only way I was able to do this was one movement at a time. Move tractor. Stop. Slowly raise bucket. Stop. Slowly curl bucket out to level. Stop. Move tractor to back of truck. Stop. Slowly lower bucket. Stop. There was absolutely no way to coordinate two movements at the same time. Move the stick a little, nothing. Move it a little more, nothing. Move it a little more, plop. I was really paranoid of beating my truck with the ultimate ugly stick! The stick is not loose, there is no play in the center position. There's just a lot of dead travel. I get the same feeling when moving dirt. Even with an empty bucket there is just a lot lack of feel in the control. I'd like to adjust it so it starts to move just off center so I would know where it should start to move instead of having to hunt for it.
   / Is there any adjustment for the FEL joy stick on the MT125? #2
Sounds like a lot of "dead travel"..... When I had my 125, the joy stick had maybe 1" of play at most.... could really feather the movement Of the bucket.
I would definitely call your dealer, could be a faulty valve. Don't forget you only have 1 year warranty on the loader....
   / Is there any adjustment for the FEL joy stick on the MT125? #3
I had a similar problem. Mine was free travel. Ended up being a few loose nuts on the valve. Look for a post LS MT125 FEL valve fix. I’m not sure if it is the same issue, but it doesn’t hurt to check.
did you see any adjustment in the valve?
   / Is there any adjustment for the FEL joy stick on the MT125? #5
I took the rubber boot off the valve and tightened the two nuts. I’m not sure if it’s the same problem. On my post about the FEL valve fix I posted two links to YouTube where I have a video posted of the problem
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2012 John Deere 410K (A47384)
2012 John Deere...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2015 Nissan Pathfinder Platinum SUV (A50324)
2015 Nissan...
