Okay, so I'm tilling a fire break along the edge of my place and 'pow' the hydraulic pump housing busts, oil runs out on the ground, and I can't pick up the loader or tiller. I get the implements dropped and the tractor in the shop, find a replacement pump, and am ready to put it on. But wait...why did it bust in the first place? Well, hmmmm, there must be a pressure relief valve here somewhere that is stuck closed. A hydraulic pump is positive displacement, so when the valve for the rear lift is closed, something has to let that pressure through to the return line or else the weakest point is going to break(turned out to be the aluminum pump housing). So I remove the control valve(right side of seat mounted on transmission case) and tear it apart. Then I pull out the set of manuals I bought from Hoyt tractor in Texas, you know, the parts catalog that is all in Japanese, and an English version service manual that has all the parts manuals same exploded views copied into it, some photo-copied pictures that are unreadable, and no details about the hydraulic system or how presssure relief is handled. No help!
SO...my next question is...
Are any of you guys out there familiar enough with the hydraulic system to guide me to the pressure relief function? I really don't want to put on this $500 pump and have it split open the minute I fire up the tactor.
I am anxiously awaiting the wisdom that I know is out there......somewhere.
