Iseki TS1610 Solenoid questions??
   / Iseki TS1610 Solenoid questions?? #1
jfulps
lockhart, tx
Iseki TS1610
What could be the problem with the Solenoid?? I went to start the tractor and there was Nothing!! We have a brand new battery so that's not the problem!!
One thing is today we found out that if you give the Solenoid a few hits with a wrench or what not it will crank over and start!! What could be the problem there!!
I found one for like 50.00 Bucks or so !! Is that okay?? or is there a cheaper one or one that can go with a TS1610 that is cheaper??
Just let me know! I don't want to keep taking off the side guard and have to hit the Solenoid every time I start the tractor!!
   / Iseki TS1610 Solenoid questions?? #2
It sounds like you should replace the solenoid. That is a sign that parts are worn out, and the rest will fail eventually and the wrench will not work. From what I found, %50 seems about average. You can look on eBay, but that is hit or miss. This is a good article that explains it in more detail and how to test you solenoid: Bench Testing a Starter Motor. I use Stevens tractor for a lot of parts, and if they dont have it listed, you can call, and they can often get it in. They have very good prices, and I think that they are in TX. Search results for: 'TS1610'
Good luck with it, and hope this helped a bit!
   / Iseki TS1610 Solenoid questions?? #3
I had a similar problem on my TS1610. Sometimes it would start and mostly it would not start.
When I pulled back the solenoid about a quarter inch by loosening the screws the tractor started. So I ordered a new solenoid for $32 and installed it. Same problem, it didn't fix it.
Then I tried cleaning and greasing the throw out assembly on the starter shaft. That assembly looked rusty. Then I installed the starter back in the tractor. Same problem again, it wasn't fixed.
So then I ordered a new starter. The new starter fixed it.
It order this part on ebay: "STARTER SOLENOID Chevy GMC Honda Isuzu Opel Blazer S10 Jimmy Civic Pickup
Item# 330717176336" The hot and ground were reversed from the orginal on this selenoid.
I still have the new solenoid on the old starter I removed.
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Case 830 Tractor (A50514)
Case 830 Tractor...
