Iseki TS1910 fuel filter
   / Iseki TS1910 fuel filter #1
Paul2
North Carolina
Iseki TS1910
I just took my TS1910 out of service to perform numerous service items. One was a change of the fuel filter and cleaning of the bowl. Everything went well except for the fuel filter gasket. I can't seem to get it to seal without leaking. I installed a new o-ring which fits snugly around the bowl. That didn't work. I went back and got an o-ring that fit the knurled metal ring that holds the filter in place. That didn't work either. What do I need to use to get this thing to stop drooling?? Thanks for any suggestions!!
   / Iseki TS1910 fuel filter #2
I had the same problem with my John Deere 2010. The problem is alignment. I had to disconnect my fuel lines, remove the bulb and install the gasket and bulb off the tractor in order to get it aligned correctly. It was a pain but took less time and wasted fuel than trying to get it sealed while on the tractor. I tried six times to get the bulb and gasket right and failed every time. Come to think of it, I had the same problem as a kid, not sure if it was me or the things in the way on the tractor. Give it a try. Good luck.
Farwell
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2016 Ford F-550 Palfinger PSC3216 4,000LB Crane Service Truck (A51692)
2016 Ford F-550...
Trail-Sport TS21RBH RV (A50121)
Trail-Sport...
2010 Toyota Camry Sedan (A50324)
2010 Toyota Camry...
