JD 1026r vs kubota bx2370
   / JD 1026r vs kubota bx2370 #1
Smf834
Bronze Member
SW WA
L2501
Both subcompact, JD is a bit heavier and more hp. Both less than 300 hrs. Any benefit to one over another? Or mostly brand loyalty? Thank you.
   / JD 1026r vs kubota bx2370 #2
How do they both look and operate? Either of them beat up, regular maintenance done on both (try and confirm with either log book documentation, or check fluids/grease points/lugs/etc yourself).
Both looks to be well taken care of. Good paint, no rust, recent trip to the dealer for maintenance checkup. Both about 15k, with fel and mid mower. Is it a fair price?
Also, is a 16hp Kubota b7300 will be significantly inferior to its 25hp subcompact?
   / JD 1026r vs kubota bx2370 #5
Only if the b7300 has a FEL. From what I see, the B7300 doesn't have power steering and the others do. Anyone who has ever used a small tractor with small wheels and a FEL will wish for power steering - but of course it is probably half the price.
I'm surprised at just how similar the JD and the Kubota seem to be on specs. What are the differences?
   / JD 1026r vs kubota bx2370 #6
Here was my contribution:
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
28013 (A50322)
28013 (A50322)
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
