JD 110 TBL computer code
   / JD 110 TBL computer code #1
L225
east central florida
Kubota L225
I have a JD 110 TBL and I'm getting a computer code flash of 3 shorts and 1 long. Any ideas on this one ? The tractor was purchased a number of years ago by me with about 100 hours on it and I only use it as a "toy" on my small hobby farm. I have put about 600 hours on it and always maintained it well. (oil, filters, etc.) It has been kept inside when not in use. I called the dealer and they were no help !
Thanks for your time and I hope someone can help!
L225
   / JD 110 TBL computer code #2
The code is for the throttle position sensor. Either the sensor is bad, or more likely it needs adjustment. These are the voltage specs. Specification:
Input Voltage . . . . . . . . . . . . . . . . . . . . . . . . 5.0 ± 0.2 volts
Low Idle Position Signal Voltage. . . . . . . . 0.4 - 1.0 volts
High Idle Position Signal Voltage . . . . . . . 3.2 - 4.5 volts
Be sure to use a digital voltmeter to check. Analog meters can damage the controller. The wires all need to stay connected when testing. Back probe the connector with a needle or pin to make contact with connector.
   / JD 110 TBL computer code #3
check your private messages for more info
Joe
PORTABLE METAL FUEL TANK (A51243)
PORTABLE METAL...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
International Farmall 300 Tractor (A50514)
International...
3014 (A50657)
3014 (A50657)
2023 CATERPILLAR 299D3 XE SKID STEER (A51242)
2023 CATERPILLAR...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
