JD 110 TLB Joystick ball joint lubrication
   / JD 110 TLB Joystick ball joint lubrication #1
frencht
Deere 110 TLB
The joy stick on my 110 has been getting increasingly harder to operate. I looked at the joy stick linkage and didn't see any signs of lubrication. I've looked in the Tech Manual for specifics on what lubrication should be applied to the ball joints for the joy stick linkages on my 110 TLB but haven't found anything. I've squirted the ball joints with brake cleaner followed by a light spray oil to get me by. Can anyone tell me what lubricant I should be using?
Thanks in advance.
Tim
   / JD 110 TLB Joystick ball joint lubrication #2
Try spray on graphite . You can find it at farm stores .
   / JD 110 TLB Joystick ball joint lubrication #3
Door Ease costs a little more for a small can of spray on graphite and my hardware store carries it.
   / JD 110 TLB Joystick ball joint lubrication #4
I use LPS-2 and it seems to work well.
10' Poly Feed Trough (A50515)
10' Poly Feed...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
