JD 1530 Frontend loader- shutters at times and doesn't have as much lifing power
   / JD 1530 Frontend loader- shutters at times and doesn't have as much lifing power #1
lowandslow1
Graham, WA
John Deere 1530 Diesel
I have a '69 JD 1530 with a front end loader. Tractors runs nice, the hydraulics have some trouble at times. Lately, when lifting the bucket it will shutter near full extension and/or not have as much lifting power...maybe 2/3rds normal lifting or down force, sometimes it doesn't have enough power to lift the frontend off the ground. Doesn't seem to have much problem with the curl. Sometimes it works fine. Intermittent. The hydraulic fluid appears to be full- when checking it by the dip stick under the right side of the seat. Thanks guys.
   / JD 1530 Frontend loader- shutters at times and doesn't have as much lifing power #2
How long since hyd filter was changed & sump screen checked/cleaned? I'd suggest to check stand-by pressure and set it at 2350 psi. What type valve controls FEL(ind or scv)? With 3 pt raised,engine running look in hyd filler hole behind seat to see if any oil is spraying. Does tractor have the options of hyd ind pto or hyd hi-lo?
17201 (A55852)
17201 (A55852)
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
New Holland 316 Square Baler (A50775)
New Holland 316...
2006 Ford F-250 4X4 Pickup Truck (A55788)
2006 Ford F-250...
19015 (A55788)
19015 (A55788)
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
