jd 2355 8x4 transmission is it synchronized?
   / jd 2355 8x4 transmission is it synchronized? #1
schiker
Anderson, SC (Northwest part of SC)
Ford 3000, 1972 LCG, JD 5603
I see an ad for a JD 2355 tractor with an 8 F 4 R transmission.
I have never operated one but the tractor appears to be low hours clean and a decent deal. Too far to drive to check it out.
I am use to my old '72 Ford 8x2 transmission but would like something a little faster changing direction. And better speed control. Still 8 forward gears but are they better spaced for work? Is the JD 2355 reverse synchronized? Or do you have to come to complete stop before it will go into gear. I think its forward gears are synchronized but not sure of range selection/reverse.
How close to a mechanical shuttle type reverse is it?
I will use it mostly for a utility tractor cutting 20 acres of fields and maintenance around my little farm/estate driveway scraping, some dirt work, limb - brush/tree clean, fertilizer spreader, drag harrow, pasture work etc future hay cutting then who knows ???? How important is a ground speed PTO option?
Is this a pretty good model tractor or should I look for a newer model with power reverser a bit smaller (larger than compact but smaller size).
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2017 Ford F-150 (A53422)
2017 Ford F-150...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
