JD 2630 brakes
   / JD 2630 brakes #1
kab65
John Deere 2630
I have just purchased a John Deere 2630. The brakes are causing me issues. The left pedal needs to be pumped the pressurize it, the right pedal does not move. I checked the oil level and the tractor has been sitting for 5 years
   / JD 2630 brakes #2
Welcome to TBN
I suggest to lubricate brake pedal pivot pin & piston. After RH pedal/piston is freed I suggest to bleed both brake circuits. Engine needs to be at idle speed while brake bleeding is performed.
   / JD 2630 brakes #3
I agree, start by freeing the pedals.
After sitting unused for five years, I would change all fluids, filters, and clean the sump screen.
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
