JD 3020 checking hyd level?
   / JD 3020 checking hyd level? #1
MNBobcat
Platinum Member
I blew a hydraulic line. When I replaced the line I drained all of the hyd fluid and replaced it along with a new filter. Now I have a stumble in the FEL. If I run it to full extension a few times the stumble goes away until first start on the next day.
When I check the hyd level via the dipstick, should the stick be sitting on top or screwed all the way down and then removed when you check the level?
   / JD 3020 checking hyd level? #2
From the manual, "With the tractor on level ground, remove the dipstick. Obtain the oil level on the dipstick with the cap resting on the threads."
You do have a manual right? :D
Tim
Tim,
Thanks. Nope, just got the tractor within the last 2 months and haven't picked up a manual for it yet.
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2009 GREAT DANE 53FT REEFER TRAILER (A52141)
2009 GREAT DANE...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2016 Ford Explorer...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
