JD 3020 - Run rear remote hydraulics continuously?
   / JD 3020 - Run rear remote hydraulics continuously? #1
MNBobcat
Platinum Member
Hi Guys,
I have a 1960's JD 3020 Diesel.
I just bought a hydraulic post pounder set up for a closed hydraulic system on a John Deere. I have a lever on my dash that controls the hydraulics at the rear remotes. I do not recall it having a detent to stay in the "on" position. I'm guessing I'm going to have to use a bungie cord to hold it "on".
Anyone else ran into this and have a tip or suggestion?
   / JD 3020 - Run rear remote hydraulics continuously? #2
You have it figured out already. Be sure the pounder valve is really set up for CC.
It is. The manufacturer confirmed it.
   / JD 3020 - Run rear remote hydraulics continuously? #4
Deere actually made a bracket(a15664) that bolted to the dash in the scv slot. You could hook the lever on it where constant flow or pressure was needed. Unfortunately it isn't available anymore. It would be easy to fabricate though if you don't want you o use a bungee.
   / JD 3020 - Run rear remote hydraulics continuously? #5
Here's a parts photo of A15664.
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
Electric Mobility Scooter (A51694)
Electric Mobility...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
John Deere 6175M (A50120)
John Deere 6175M...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
