JD 3020 Starter Circuit breaker
   / JD 3020 Starter Circuit breaker #1
MNBobcat
Platinum Member
Hi All,
I have an early model JD 3020 diesel with the 24 volt system. There is a bracket mounted on the side of the starter and there are 2 round objects (what I assume to be circuit breakers) mounted on the bracket with wires going to the solenoid. If those are circuit breakers, is there a way to manually reset them or do they automatically reset?
My owners manual says there is a fuse but I don't see it.
   / JD 3020 Starter Circuit breaker #2
They are supposed to reset manually. They protect the lighting and other auxiliary circuits, not the starting circuit.
2017 Isuzu NPR Stake Body (A47384)
2017 Isuzu NPR...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
