noenvy
Hi everyone,
I'm new here. I hope that you will forgive my lack of knowledge of mechanics. I do try hard to understand and I have been trying to fix this problem without success. I hope that someone here can help.
I have a JD 330 diesel. I'm going to yadda yadda a lot of this story. I can fill in information if you need it.
I was mowing the grass and the battery light comes on, thought I would finish up one little spot but I started to smell plastic burning and the smoke followed shortly thereafter. I gunned it back to the barn and got the hose on it. The wire that goes from the voltage regulator to the solenoid had melted into the harness and partially melted the voltage regulator.
I have replaced the voltage regulator got the whole thing wired back together after several attempts (with the help of my auto mechanic who is just too busy to be messing around with my tractor). I took the battery too the auto parts store and had them check it and they said it was good.
The battery is overcharging. You can hear it bubbling after just a minute or two of the tractor running. When my mechanic was here the battery tested at 20V when it was running. The alternator was reading 67V. I just bought a mulitmeter and I checked the battery last night while it was off and it read 14.53V.
After hours of reading in this forum and in others I came across a post in another forum that was talking about a service bulletin that JD had put out as a fix for starting problems and battery boiling problems. It's called a starting improvement relay kit- part #AM 107421. Turns out that is installed on my tractor but it's called a neutral start relay. Now this has me wondering if the thing is wired correctly. My husband had put in a new harness or plug that attaches to the voltage regulator some time ago. He doesn't remember when or why he had to replace it. I actually suspect that the battery has been boiling for some time now just from the corrosion on parts around the battery which I have since cleaned up.
I have to get this fixed. The grass is way long. I can't afford to send it to the dealer. I have no way of getting it there. I asked today at the dealership if they would pick it up and they said it would add $200 to the bill.
If anyone has read this far and thinks they can help me figure this out I would be eternally grateful. If anyone knows how it should be wired and can tell me how the wires should go I think it would be a great start to figuring this out. I'm pretty sure that the wires from the voltage regulator are correct. I'm not sure about the wire from the relay switch. I have tried to read the wiring diagrams but they leave my stumped.
Thanks for reading......I hope someone can help
