JD 333G can joysticks usage be reversed?
   / JD 333G can joysticks usage be reversed? #1
cascade202
John Deere 333G
The loader came with the lefthand joystick controlling loader movement and the righthand joystick controlling the bucket. Can this be reversed where the righthand controls movement and the lefthand controls the bucket?
   / JD 333G can joysticks usage be reversed? #2
I’d say if you can switch the hydraulic lines around yes. For example on my J.D. 2025r it has a quick connect loader and the hoses are color coded. If I change the way they are hooked up the joystick functions will change.
   / JD 333G can joysticks usage be reversed? #3
I believe 333G is a skid steer. Not sure you swap joystick functions side to side. Does it have any option for European control Vs american?
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
Unused 2025 CFG MX20R Mini Excavator (A49461)
Unused 2025 CFG...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
