JD 3720 Hydraulic pump return hose assemply leak
   / JD 3720 Hydraulic pump return hose assemply leak #1
marshallcro
Stanfordville,ny
John Deere 3720, Farmall Cub, Bobcat 3400
I have a slight intermitting leak in the return hose assembly in a JD 3720. It looks to me like its around the hose clamp of the vertical return pipe but its hard to tell. Can the pumps themselves leak? Has anyone changed this part and can you give me some advice in replacing it and reducing contamination of the fluid when opening the system? Also could you tell me the amount of fluid that is needed from the ADD line to bring it up to the FULL line on the hydraulic dip stick? Is there a specification for the X marks in the middle on the dip stick? I'm afraid of over filling it and ending up with more work to bring it to the proper level. Thanks in advance?
   / JD 3720 Hydraulic pump return hose assemply leak #2
Well assuming that is close to my 4410/4210, I have replaced them. Mine has the 2 pumps and one molded hose going to both. I replaced mine when I did a pump rebuild on the 4210. It wasn't hard, and mine is on top of the pumps, so wasn't much fluid loss.
The pump can leak. It is stacked plates with O-rings between them. There have also been incidents with these types of pumps to crack and leak.
Where and when does it leak? If it leaks when it is running, then probably not the intake hose.
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
JOHN DEERE FC20M LOT NUMBER 55 (A53084)
JOHN DEERE FC20M...
2019 Chevrolet Malibu Passenger Car, VIN # 1G1ZC5ST5KF136071 (A51572)
2019 Chevrolet...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2012 John Deere 7280R MFWD Tractor (A53472)
2012 John Deere...
