JD 4020 weight?
   / JD 4020 weight? #3
Here is some info on the 48 loader that I've cut pasted from another forum site.
Here's some information on the JD48 loader, directly from the operator's manual:
Weight(with 60 inch materials bucket): 1,220 lbs.
Operating dimensions:
These are for a JD4020 tractor with a 60 inch materials bucket. Dimensions will vary depending on the tractor used, tire sizes, and bucket, but this will at least give you a rough idea of what to expect.
Maximum lift height to heel of bucket: 126 inches.
Maximum lift height to bottom of level bucket: 120 inches.
Ground clearance with bucket fully dumped: 104 inches.
Reach (i.e., horizontal distance from nose of tractor to front edge of bucket) with bucket fully dumped: 26 inches.
Reach (i.e., distance from front wheel hub to front edge of bucket) with bucket on ground: 68 inches.
Maximum dump angle (with loader at maximum lift height): 39 degrees (i.e., the floor of the bucket drops 39 degrees below horizontal).
Bucket roll-back angle: 9 degrees (i.e., floor of bucket can roll back 9 degrees above horizontal with the bucket on the ground).
Digging depth: 7.5 inches.
   / JD 4020 weight? #4
I don't know exactly, but well north of 10,000lbs. Could be over 12,000 with the loader and (presumably) fluid in the tires.
   / JD 4020 weight? #5
I have a wide front 4010 with a double stack slab weight on front, 16.9-38 tires that are NOT loaded with two sets of iron weights on back and NO loader that tips the scale at 9500 pounds. I know because I scaled it last fall when selling some poo.
Add 1300 pounds for the loader and another 2000 pounds if the rear tires are loaded.
More info coming soon! (A56859)
More info coming...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2013 Jeep Wrangler 4x4 SUV (A59231)
2013 Jeep Wrangler...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2002 FORD F-350 XL...
