Xjdigger
My tractor stopped running due to the fuel shut off solenoid is not being powered.
I've been studying the 4100 tech manual and it states
Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 VDC
Pull-in voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6.8 VDC
Hold voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0 VDC
I cannot find where this voltage is transformed by the control module.
Is this done internally to the solenoid or does the circuit actually provide 6,8 volts to pull in the pin and hold it with 3.o volts dc.
I've been searching the web on this part #1803es and the only information I find is 12 volt input.
Any help is appreciated.
I can run this until I find the problem by jumping 12 volts to the pull in circuit and holding the shut off open with 12 volts under the assumption that the solenoid it self converts the voltage use.
