Grove JD
I had a gear drive 4200 and I upgraded to a 4300 that I bought because it had a set of rear remotes. It came with a 60" belly mower that was plumbed into the rear remotes with hard lines. I didn't need it at that time and I have a 6' finish mower and ZTR so I took it off and never used it since. I recently have a need for it and am trying to figure out if there is a way to reinstall it on the tractor and still be able to utilize the remotes. I have a hydraulic top link that I would like to leave on the tractor.
I'm not sure I understand all the acronyms and terminology for the options I need/have/want so please correct my foolishness if I say something wrong in describing how the tractor is currently equipped.
The tractor does have a 420 loader and the factory installed loader remotes (DSCV?) It has one set of rear remotes that are controlled by a single cable lever on the right (passenger side) fender. I'm unsure if this is the power beyond kit or the extra rear SCV.
Does every tractor with a MMM have remotes? Is there a way to use the MMM without the hydraulics? If no do I need to install additional rear remotes to be able to hook the MMM and top link up at the same time? Is there a way to do so without the hard lines that would make that remotes accessible when the mower deck was removed?
I would also like to explore the option of adding a front remote for a grapple bucket and maybe even the tilt feature in the future so please keep that in mind with any advice.
Thanks,
Grove
Thanks,
Grove
