JD 4410 Hyd. Pbelow problem
   / JD 4410 Hyd. Pbelow problem #1
tractorslinger
Advertiser
Fort Wayne, IN
John Deere 4410 w 430 loader and 72" Deck/Case IH 245/Ford 9N/X324
I have a JD 4410 with 900 hours on it. I bought a 72 " finish mower a month or so again. I noticed when lifting the deck, there was a growl coming from the pump. It does it at 1600 rpm or below. If you lift it all the way to the highest point, the noise isn't very load, but when lifting to a desired height, its much loader. My loader is making the same noise, but only at 1400 rpm, not below or above at all.
I changed all fluids, filters, screens. No metal in suction line, but did see metal flakes in drain pan after changing fluid.
Loader/ 3 point operate as they should. No drop, no performance loss.
Any ideas?
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
Demco 365 Gravity Wagon (A50774)
Demco 365 Gravity...
1996 CATERPILLAR 416B BACKHOE (A51242)
1996 CATERPILLAR...
2020 Freightliner M2 106 Dump Truck (A50323)
2020 Freightliner...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
