jd 445 steering cylinder
   / jd 445 steering cylinder #1
toyfarm
Connersville, In.
2013 Kubota B3200
Anybody point me in the direction for one of these for less than $270
I prefer used in good shape but open to new at a reasonable cost!
John Deere part number is AM118796
   / jd 445 steering cylinder #2
What happened to the cylinder? Not repairable?
well for one it don't appear to be re-sealable (welded shut) for 2 it turns much sharper one direction than the other and for 3 it appears to be leaking thru the casting around the seal and not the actual seal! So i assume i'm looking for a replacement?
   / jd 445 steering cylinder #4
Unfortunately JD uses welded cylinders on a lot of smaller tractors, and they are "non-standard" forcing you to buy a replacement from them. My only suggestion would be to find a local shop and see what they can do for you.
unfortunately there are no hydraulic cylinder shops within 70 miles of me! by the time i do all the runnin around and chasing a better deal, more than likely be better off to bite the bullett right off the bat??
   / jd 445 steering cylinder #6
I'd prolly do that too.
Thought you might find one on eBay from someone parting out a 4xx. Didn't see any listed now, but some different sellers look like they have some parts and might be worth a contact or two.
i've been all over ebay...this one in particular i contacted seller asking if it would interchange? There are 3 diff. ones that fit 445 alone (depending on serial number) so i would want to make sure that it would interchange! Still no return msg from seller. Also there are not several as this is the only one i found that was even close! There have been several in recent history that have sold though, perhaps I should mow with the big ole Kubota until one can be located reasonably?
   / jd 445 steering cylinder #9
The 420 is a different frame tractor from the 425, 445, and 455. I would be very suspect of a 420 steering cylinder for your 445. Among the 445's are the AWS that likely take a different steering cylinder. Ask for the measurements, as it might be easy for a seller to say yes and then the "not-so-much-fun" would begin. ;)
   / jd 445 steering cylinder #10
They are repairable with a lathe and the proper welding equipment (TIG)
The butt plate needs to be machined apart (opposite side of the rod)....then rebuild, reweld and test.....Done......
They take standard seals internally.....
2022 CASE CX130D HYDRAULIC EXCAVATOR (A43004)
2022 CASE CX130D...
2020 Terex RL4 4000W Towable Light Tower (A44571)
2020 Terex RL4...
Club Car 1700 (A44391)
STORAGE FEES (A43003)
1999 Ford Econoline Van, VIN # 1FTRE14W0XHB81450 (A44391)
1999 Ford...
2012 FORD F550 UTILITY TRUCK (A43004)
2012 FORD F550...
