JD 4520 Electrical issue?
   / JD 4520 Electrical issue? #1
wahoogator
Jacksonville, FL
John Deere 4520
I have a 2009 JD 4520 that's driving me crazy trying to figure this out. The tractor dash blinks repeatedly and the relays are clicking and other heavy clicking noises
that I cannot locate. Ive been told I probably have a short somewhere,(duuu), bot I can't track it down. I have full power to the starter, alternator, etc.etc.
PLEASE HELP !!!
I'm going crazy over this...
   / JD 4520 Electrical issue? #2
I would start by physically detaching, wire brushing, and reattaching cables at battery and ground points regardless of what they look like on physical inspection
Thanks for the reply. I am now able to keep the dash lit up but, when the keys turned to Start dash dies, so trying to jump start the Starter dash dies also...
   / JD 4520 Electrical issue? #4
What did you do to be able to keep the dash lit up?
Welcome to TBN
Just went through what switches and wiring to inspect. Maybe something came to life… I hope it’s not a short, there was evidence of a mice nest from last year 🤔🫢😵‍💫🤢
   / JD 4520 Electrical issue? #6
Have you recently cleaned/tightened ""all 4 battery cable connections""?? If not you need to perform that simple task!
Front End Loader Joystick and Pump Sprayer (A54865)
Front End Loader...
2022 Polaris Ranger 4x4 Utility Cart (A55851)
2022 Polaris...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2017 TROXEL 150...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
2018 Ford F-550 Flat Bed Truck, VIN # 1FDUF5GTXJEC35552 (A54865)
2018 Ford F-550...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
