JD 455 Side Slope Mowing-32.6 degree's
   / JD 455 Side Slope Mowing-32.6 degree's #21
that would be wait till it gets knee high, and bust out the gravely 30" with duals :D
   / JD 455 Side Slope Mowing-32.6 degree's #22
What you need is a pair of duals, and a roll bar. Then you would be able to sit on the seat normally.
I can get off on the low side @ 30 degrees. Havent been on anything steeper, dont want to damage the engine.
   / JD 455 Side Slope Mowing-32.6 degree's #23
I believe you dirt,,no pictures required.
You guys ever see a side boom? Its a dozer with a boom on one side and weights on other side,the weights move out and back as required for load on the one side and slope.
Think those state road mowers with the mower on the side works the same way,weights on one side that come out or in and mower on the other side. They mow on some pretty steep angles side ways,they got a mower behind too,,money money I bet,but for some,money ain't a question,[not for us chinese tractor owners of course],,thingy
   / JD 455 Side Slope Mowing-32.6 degree's #24
Lets see more pictures of this rig....
schmism, it just would not look as nice if I let it grow that long and then mow ocassionally.
Mith, if that slope was the only thing I was mowing with the 455 the duals would be a good and safer option, but I also have to mow my yard. I would not be able to get the edge of the mower tight on anything because the dual would be wider than the mower. Good thought though for just slope mowing.
Barry thanks for the 45 degree engine info. I'll keep that in mind if I ever decide to go steeper.
   / JD 455 Side Slope Mowing-32.6 degree's #26
Woodland, I've got a picture of the front. Some of the parts of the loader are missing.
Front pic
Dirt, I can see you would have a problem with edging. Maybe put duals on one side, and always have that on the lower side on the slopes. Edge with the other side. (I hope you dont mind my putting pictures in your thread)
   / JD 455 Side Slope Mowing-32.6 degree's #27
seems like the only time you have to worry about the steepness of a sideslope is the very first time you are on it ...and the very last
mith, no problem with the pics. Feel free.
JoeL, good point! lol
   / JD 455 Side Slope Mowing-32.6 degree's #29
Mith and Dirtworks. I spent big coin on a tractor that does slopes. Even with the tilting seat, wide tires the pucker factor is far too high for me at 30 degrees (and I can go to 45 and other owners work around 55 they say). Anyway. Impressed. Not having the ROPS is the only downside but if you felt like you were going over you could probably get off the machine as it is so low...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
