JD 5103 loses power and blows white smoke
   / JD 5103 loses power and blows white smoke #1
ashelton79
John Deere 5103
I recently bought an '05 5103 with a MX6 rotary cutter, it had 165 hours when I bought, I have put 40 hours on it. I was cutting a 44 acre pasture two days ago when the tractor lost power and started blowing some white smoke from the exhaust. I talked to friend who suggested I change the fuel filter, but after an hour the same situation happened again. I have drained the fuel, changed both the fuel lines, and I still have the same problem. After about an hour of cutting i lose power and the tractor blows white smoke. I have to shut it down for 20-30 then it will crank up fine and run for about an hour and the whole thing starts over again. Any suggestions on what the problem might be?
   / JD 5103 loses power and blows white smoke #2
Possible a partially blocked fuel return line. Originally I thought the engine was siezing but you say after a few minutes it starts fine. The one question I have is if you try starting immediately does it crank at normal speed or is it v-e-r-y slow. If it cranks slowly then you might have a motor that's siezing up.
Good luck.
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
John Deere 6210E 120HP 4WD Agricultural Tractor (A50322)
John Deere 6210E...
2011 Liebherr L586 (A52748)
2011 Liebherr L586...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
