jd 5220 lift arm ball
   / jd 5220 lift arm ball #1
rfhjr
Salisbury NC
John Deere 5220
I was writing to ask how to go about replacing a John Deere 5220 category II lift arm ball which has been lost. I know on some tractors these are held in with a pin but this one looks like there are welds on the lift arm. In looking online there are just the balls listed, weld on ball joint and a weld on ball with lift arm. I did not know which one should be used and if it is welded is it a matter of grinding the weld to put in the replacement. Thank you
   / jd 5220 lift arm ball #2
   / jd 5220 lift arm ball #3
I agree with JD5210 as it appears the draft link balls are replaceable/interchangeable Cat l or Cat ll
   / jd 5220 lift arm ball #4
I am unsure about your model but I have welded on several on other tractors. Just measure back from center, cut and weld. I prep the new piece with a bevel leaving about 3/16" landing, then cut and grind lift arm. I use 7018 3/32". But if a new can popped in that puppy that's easier!!!!
   / jd 5220 lift arm ball #5
Had one that was drilled for Cat 1 on one side and Cat 2 on the other side....same ball. Had ball split and fail. Wound up taking a PortaBand saw and cut "lip" off around ball. Bought a new Cat 2 ball, replaced it and welded "lip" back to arm. Seemed to work fine with no issues during the rest of my ownership. Total investment less than $50.
3000 Gallon Black Poly Water Tank (A45336)
3000 Gallon Black...
2018 Ford Focus Hatchback (A46684)
2018 Ford Focus...
Homemade P.T 6'x14' 2 Axle Trailer (A44502)
Homemade P.T...
2023 HELI CPYD25C FORKLIFT (A47001)
2023 HELI CPYD25C...
2005 Freightliner FS65 Chassis Thomas School Bus (A46683)
2005 Freightliner...
2010 VOLVO VNL TANDEM AXLE MID ROOF TRUCK (A45676)
2010 VOLVO VNL...
