JD 5320 FEL Hydraulics Noisy
   / JD 5320 FEL Hydraulics Noisy #1
Bracken Farmer
Bemboka
Looking
Greetings all,
My JD 5320 FEL makes horrible noises when I lift and lower the bucket. it sounds almost like a shuddering from the hydraulics.....The FEL has recently been fully greased. I would appreciate any suggestions as to the things I should check to work out what is wrong.
Doug.
   / JD 5320 FEL Hydraulics Noisy #2
First thing to do would be change the hydraulic filter. If that does not help, I would remove and clean the sump screen. Also you possibly could have a suction leak at the line between the hydraulic pump and filter housing. Do you see any difference in lifting speed or loss of lifting power? If not, still could be a binding pin in one of the loader pivots.
Hi, many thanks for the advice ! I will move to change both those filters. I do see a difference in the lifting speed. Sometimes non-responsive, especially when going horizontal on the stick; i.e. trying to make the bucket empty. Some kind soul from here provided me with the e-manuals, so I can get to work on it.
2020 PETERBILT 567 DAY CAB (A53426)
2020 PETERBILT 567...
2014 Ford Escape (A50324)
2014 Ford Escape...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2021 Kubota SVL97-2 (A50123)
2021 Kubota...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
