JD 620 starting problem...
   / JD 620 starting problem... #1
mantiup
florissant co.
1958 jd 520 &620
My 1958, 620 will start and run as long as I keep the starter engaged ....stops firing when starter is disengaged....any ideas????
   / JD 620 starting problem... #2
From what I understand you saying, it is only running on the starter. If the engine fires, it will outspin the starter.
But hang in there, as some help and things to try will be forthcoming.
Can you give us some history... battery, plugs, fuel, spark, parked long, etc.
   / JD 620 starting problem... #3
Read my reply to your question on the other forum. Ign resistor is bad or wiring leading from resistor to coil is faulty.
2025 CFG Industrial M-DRG (A50123)
2025 CFG...
Altec Boom Truck Body (A51692)
Altec Boom Truck...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
91013 (A48082)
91013 (A48082)
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
