JD 650 Smoking and won't run
   / JD 650 Smoking and won't run #1
tbaker4
Lawrence, KS
John Deere 650, Ford 2N
My 1986 JD 650 will not reliably start. On the rare occasion it will, it blows thick white smoke for a while, then it appears to run normally and suddenly stops running without explanation. I don't know much about 3-cylinder diesel engines, but I think I have some kind of fuel problem, perhaps a bad injector. Fuel is new and I replaced the fuel filter. Please help.
   / JD 650 Smoking and won't run #2
Are you certain there is no water in the fuel? Did air get in the injector lines when you changed the fuel filter? I would put in a water displacing fuel additive and bleed the injector lines.
   / JD 650 Smoking and won't run #3
MAKE SURE u have fuel AT the inj. pump INLET.. open the bleeder & watch the fuel POUR out.. then close it.
Loosen the steel line AT THE INJECTORS & crank the engine.. wait till fuel squirts out & tighten..
DONT burn up your starter.. crank for a 10 count & stop & give it a rest & do it again till fuel squirts out..
IF it doesn't/never squirts out.. THEN u have a problem.. Cuz if u have fuel going IN & none out.. then u have inj. pump problems.. OR a shut off problem.{cable or electric}
MAKE SURE the throttle is in the wide open position.!!
   / JD 650 Smoking and won't run #4
Check your fuel pump on the side of the engine. My F1145 front mower was doing the same thing. Its a 28 hp JD front mower w a Yanmar motor. Unhook the fuel line coming from the fuel pump at the filter and see if when you crank over the motor if you get any fuel. If not , thats your problem.
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
2016 Ford F-150 Pickup Truck (A44572)
2016 Ford F-150...
Safety Basket Forklift Attachment (A44571)
Safety Basket...
2014 Crane Carrier Low Entry New Way 31Yd Side Loader Garbage Truck (A44571)
2014 Crane Carrier...
Hyper Tough H2510 Weed eater (A47484)
Hyper Tough H2510...
2004 Rosco Challenger 2 Ride-On Rotating Sweeper (A44571)
2004 Rosco...
