JD 650 starting
/ JD 650 starting #1
art
Super Member
central New York
all makes and models
I figure I'd toss this out for an easy way to fix this problem for a customer. There is a wire (Rectifier) by the JD parts list that grounds out and goes through to the starter. part number CH20161 this part has been discontinued since 1988 and is currently unavailable thru the dealer. Is there a good way to replace it? Is it available through Yanmar or just JD?
/ JD 650 starting #2
To my knowledge, this is not a rectifier. It is only an adapter that allows hook up to a starter that has a stud for solenoid activation. You should be able to splice in a piece of wire with an eyelet on the end to connect to the starter. Good Luck!
/ JD 650 starting
This unit is under the dash panel and has a multi wire connector on one end and the ground coming out on the other. It would be on the left bottom of the console.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A59230)
2021 Ford F-250...
2005 JOHN DEERE 160C LC EXCAVATOR (A59823)
2005 JOHN DEERE...
2016 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2016 Nissan...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
