JD 755 mid 60" mower PTO shaft
   / JD 755 mid 60" mower PTO shaft #1
Roughryder
I have an older mid mower on my jd755 and the pto shaft is worn out. The part I need is AM107599 and I cannot find it. I did locate a AM101858 which is also for a jd755, but with a newer mower. I know the AM101858 shaft has a different implement end. So, I know I can remove my old end and install it on the AM101858, both shafts use the same cross bearing. But will the lengths of both shafts the same ? My shaft is a clamp style while the newer shaft uses a spring roll pin. Two local dealers are no help....
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
JOHN DEERE 1700 LOT IDENTIFIER 17 (A53084)
JOHN DEERE 1700...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1262 (A50490)
1262 (A50490)
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
