I have JD 850 mini tractor with backhoe and loader. Recently the backhoe jammed up and fluid started oozing out of seals everywhere and pump starting squealing. It was like too much hydraulic fluid was driven into the controls and overwhelmed them.
Disconnected the backhoe and tried the loader and it squealed ONLY when not using. Worked fine up and down and bucket but squeals as soon as I stopped.
My guess is relief valve may be stuck or blocked.
I drained fluid, cleaned filter, replaced fluid and still no change. Where is the relief valve located? Am I guessing along the correct line?
