Mr Winston and others, no blow by out of vent tube. So correct me if i am wrong, the piston is a slip fit inside of the bore of the cylinder and the rings seal up the slip fit clearance to achieve maximum compression. Having said that then where or how is the crankcase oil getting into the cumbustion chamber to exit the engine as light blue exhaust smoke? The tractor is a 1990 JD 955 with 963 hrs. Plus ll JD 15-40 engine oil is what I am using not sure what previous owner used. Other than engine oil going from full to add in 10 hours tractor starts good, runs smooth, plenty of power. Someone from the JD forum said to change oil more frequently and use a high detergent oil for a couple changes. What brand and weight high detergent oil would any of you recomend?
