canucklehead
- Joined
- Nov 29, 2006
- Messages
- 314
- Location
- frozen Canada
- Tractor
- 1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
Howdy all, first time poster!
I bent the mid PTO driveshaft on my JD790, using my snowblower. also tore off the front PTO mount (which will need to be welded back on and maybe reinforced).
According to JDs parts catalog page, a new shaft will cost about $310. this appears to be a telescopic shaft (not sure why... the shaft goes from the gear box at the rear, directly into the front PTO). only reason i can guess is so that you have a bit of room to use those quick connect couplings to pull it off/on the PTO stub. (interesting, the "front PTO" is more like a coupler to connect the mid shaft and front shafts together).
so I went to a couple of driveline shops and they can't straighten this shaft. COULD I use another telescopic shaft like the one I use for my brush cutter? (I'm guessing it's not strong enough to withstand that torque).
Some of the JD parts sure seem expensive, especially from our local dealer. Is there ANYONE who's known as a volume/discount JD dealer? I don't mind mail order. I know for Honda products (for example), there's a great place to mail order from; Service Honda Home of the CR500AF - Honda Motorcycle Parts .
LAST.. Anyone sell aftermarket driveshafts, or other aftermarket parts for reasonable/cheap prices? I could barely afford the tractor, I sure can't afford the retail price of JD parts!: eek:
Thanks for any help!
