JD L130 cutting off under load
   / JD L130 cutting off under load #1
KTKelly
Oak Island, NC
JD L130
Bit of a puzzle.
MY L130 will fire up and run great. Until I engage the blades.
At that point it may run for 5 to 10 minutes, or it may almost immediately shut down.
I presume it's a bad switch, but am not sure which one would be the culprit.
Details:
1. The RIO switch doesn't seem to work at all, so I am going to use a simple jumper to bypass it.
2. I haven't tested the seat switch, and I wouldn't mind bypassing it, but I would need to know which wires to jumper (there are three to the switch - One black with a black jumper to the ext position, and then two black with white stripe).
3. I don't suspect the PTO switch, or the PTO itself, as the blades will engage, and will run for at least a short time (it varies).
Any other switches that could be at fault? I'd rather not take it to the dealer and pay through the nose to get a 10 year old mower repaired...:(
Thanks in advance....
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2012 John Deere 410K (A47384)
2012 John Deere...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
