JD LA140 Starter won't crank the engine
   / JD LA140 Starter won't crank the engine #1
sundogbrew
Coatesville, PA
John Deer LA140
OK so I bought a LA140 from the Depot about 5 years ago or so. This problem has been driving me crazy for about 4 of them. Regardless if I try to start off the battery or jump it, the starter doesn't have the power to crank the engine through the compression. I have to advance the engine past the compression by hand by turning the plastic flywheel cover. Once past that it will turnover. Even if it has been running for an hour and I shut it off for a minute. Now that it is a bit older and doesn't start as easily this is becoming a much bigger PITA since I will probably have to do it a few times before it will actually start. It is like the starter isn't enough for the engine? Once it starts to turn it spins fast and sounds fine. Any help would be greatly appreciated.
Joe
   / JD LA140 Starter won't crank the engine #2
You need to adjust the valves. The compression release isn't working.
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
1408 (A57192)
1408 (A57192)
15200 (A56857)
15200 (A56857)
24017 (A56859)
24017 (A56859)
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
