JD LT190 lawn tractor......
/ JD LT190 lawn tractor...... #1
Todd Boring
Plano, IL
John Deere LT190
Hello all......new member here with a mechanical question.
Our LTD190 is a little over 10 years old and we have it serviced on a regular basis. Yesterday afternoon I went out to mow and it ran fine for about 15 minutes and then just stop running....like it wasn't getting any fuel. It will restart but does not run for long before shutting down again. Any thoughts on what might be causing this? My best guess would be the fuel filter....
/ JD LT190 lawn tractor...... #2
Try the fuel cap vent, it blocks up and causes a vacuum in the tank.
The fuel filter looked dirty and while the mower was running I could see the filter spinning so I figured a $5 filter would be a good place to start.
When I went over to pick up the filter I checked the invoice to make sure it hadn't been replaced in May........we took it in for some belt and pulley issues and they also replaced the carb because they said it was running rough. I'm a little bit annoyed that they would replace the carb without replacing the filter first.....would have saved me about $300
So anyways.....I replaced the filter and it's running fine now
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2001 John Deere 6210 (A60462)
2001 John Deere...
Caterpillar Service Letters from 1960s and 1970s (A63117)
Caterpillar...
