JD RX75 transmission ?'s
   / JD RX75 transmission ?'s #1
lithia,fl
John Deere RX75
Hello everyone, after lots of searching, I finally found the garden tractor of my dreams. It's a John Deere RX75. Everything seems to be ok except for the starting solenoid (thats what I think it is, it clicks or cranks slowly on a full battery). But I'm concerned with the transmission (only because a new one is $800 : ), I want to know where the dipstick/ level check is, I've jacked it up and cant really see anything. Any help is greatly appreciated.
-God bless
Dominic
   / JD RX75 transmission ?'s #2
Those transaxles are a sealed unit .There is no way of checking them . They are packed with grease when built . If it is working okay , don't be too concerned . They do need to have drive belts that are in good shape . It is basically a forward / reverse trans. with a variator system for gears 2-7 . Tou should try and find a service manual for it . Hope this helps .
Thanks for your response, I'm sure glad that the transaxle is one less thing that I need to worry about on the 30+ year old tractor :)
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
Little Giant Poly Water Tank (A50515)
Little Giant Poly...
