JD STX46 Won't Start
   / JD STX46 Won't Start #1
PitbullMidwest
Platinum Member
SE Iowa
1998 Kubota L2900GST
JD STX46 Won\'t Start
I have a JD STX46 with a Kohler 14 hp motor. Because it's been so dry, I haven't needed to mow in about 4 weeks. The mower ran fine when I parked it but when I tried to fire it up last night it would not start.
I drained the tank and put in fresh fuel, checked the fuel line and have gas to the carb, gas in the bowl and vacuum. If I pour gas in the throat it will run until the gas is gone so I know I have spark.
Any ideas?
   / JD STX46 Won't Start #2
Re: JD STX46 Won\'t Start
In these situations I like to replace the fuel filter. You may have a bit of debris in the filter. Also check battery voltage to make sure engine is spinning fast enough to start. If air filter is clean, then you have checked all the simple stuff. From there you will need to rebuild the carb.
On my stx46, the engine is never an issue, it's always the bagger belt and elec. system that's a problem.
2015 INTERNATIONAL 4300 BOX TRUCK (A51222)
2015 INTERNATIONAL...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2020 KUBOTA RTV...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
