JD Wheel Extensions
   / JD Wheel Extensions #1
dirtworksequip
Veteran Member
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
I was ordering a 4 in 1 bucket for my 300cx loader the other day and got to talking to the salesman and he said that Deere came out with 4 inch wheel extensions for the 3x20 series tractors. I am assuming that they will also be available for several other models. I had bought 4 inch extensions from Unverferth and was pleased with the increased stability. I did not ask what the Deere extensions cost.
Just thought I'd throw the info out there for anyone interested in a more stable tractor.
   / JD Wheel Extensions #2
I would be interested to know if they are going to offer extensions/spacers for the 2520 as well. I would only need 2" per side, mainly to get more tire clearance for the 46BH and the 3PT arms. Would also be nice to have a little extra stability too.
   / JD Wheel Extensions #3
One of the more noticable characteristics of the cab models is the "pucker sense" that they're top heavy.
I really liked the layout and the features of the 4320 cab model that the local dealer had on the lot --- but it sure seemed way tall for the base!
4 inch wheel extensions would be one of the first things I'd order on a new cab 3000 or 4000 twenty series.
   / JD Wheel Extensions #4
I saw some techs shaking a stock 3320 or 3720 with a cab on it and it was definitely easy to get rocking. Looked like you could send it over kinda easy. I looked at my turfs and if i added spacers they would interfere with the MMM deck. But I think they are wide enough
   / JD Wheel Extensions #5
i would imagine the cost for those hub extensions has gotta be higher than Unverferth units. Especially if they have standard 4 inchers available for the 3x20 series tractor.
AKfish, I bet I could lay a stock 3520 on its side real easy on dead flat ground. Get up a little speed and raise the loader up and cut it hard to the left. They just are absolutely unstable as they come new out of the box.
Sincerely,
Dirt
   / JD Wheel Extensions #7
Sincerely,
Dirt
Even worse with a cab. I saw one guy get a 3320 Cab, rockin' pretty easily by pushing on the top of the CAB:eek:. Kinda shocked me. The local dealer here advised that the 3x20 series CABs were more unstable than the 4x20 CABs, but both can be scary on the narrow tire settings.
   / JD Wheel Extensions #8
Does anyone know the JD part number for the 4" wheel extensions for the 3000 series?
Thanks,
   / JD Wheel Extensions #9
Whoee --- Nuru! Those are some wide, fat hummers! You could take your tractor swimmin' and be just fine!
   / JD Wheel Extensions #10
Yeah, and they were somethin to handle and move around. Pretty deep rims too!
Case-IH 140 Maxxum (A47307)
Case-IH 140 Maxxum...
2020 MACK GRANITE 64BT TRI-AXLE DAY CAB (A45678)
2020 MACK GRANITE...
2019 Chevrolet Express 2500 Cargo Van (A46683)
2019 Chevrolet...
1993 Ford Supply Truck (A47307)
1993 Ford Supply...
Generac 2000 (A47307)
2022 Ford F-150 XL (A47307)
2022 Ford F-150 XL...
