JD wirng diagram needed
/ JD wirng diagram needed #1
jaotguy
Veteran Member
Ottawa, Ont
Ariens
I have two JD 667A's and want to modify one for for winter use .
I need the full wiring diagram to change the interlock switches, so I can add another function / interlock.
Thx in advance ....
/ JD wirng diagram needed #2
If me, I'd either get the service tech manual, or stop by my Deere dealer and have them pull up the wiring schematics and print them off. Or can hope someone can dig them up for you here on TBN. good luck....
the AUTHORIZED JD shop here isn't very helpful, won't print off a copy , but will order the service manual with a 3 - 4 week wait for delivery ... and is a 60 mile drive one way ....
there will be snow on the ground before I can finish the wiring , if I go that route .
/ JD wirng diagram needed #4
Have you checked eBay? or searched the net for a copy? Might be a hard one to lay your hands on for that model, and be careful who you order one from... believe scammers are lurking on the net.
already checked the net and other online sources ... none showed up ...
worst case is cut the looms and trace each wire , but I'd rather not do that if I don't have to.
