JD with K46AC transaxle wont move, just clicks
   / JD with K46AC transaxle wont move, just clicks #1
youngunn
John Deere L120
i have a JD with the K46AC transaxle, and 160 hrs on it. when put into gear, forward or reverse, it wont move at all, and makes a metal/grinding/clicking noise. the axle disengage seems to be working ok. being a mechanic, i decided to pull the transaxle out and disassemble it. all the gears looks fine, no metal shavings or pieces on the magnets, fluid is nice, golden color, all looks fine. i didn't pull the pump shaft to see if it was stripped, but from your experience guys, what should i look at?
i am wanting to just sell the mower, so i don't really care to put a new pump etc in if it isnt needed. i just need the mower to move again.
thanks
bump
any suggestions at all guys?
   / JD with K46AC transaxle wont move, just clicks #3
I would check the drive pulley first then inside the gears for the pump. Are both of the wheel keys in? That seems to be a overlooked problem when people push the wheel on they forget to put the key it or push it out if it was already in there. Do a searck for "tuff torq" there is a great thread on oil change and repair.
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2010 PETERBILT 367 HOT OIL UNIT (A53843)
2010 PETERBILT 367...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
