JD345 pro won’t disengage
   / JD345 pro won’t disengage #1
345milo
JD345 watercooled
I was wondering if anybody had this happen, my clutch is maybe 3 yrsold worked great until this week, went to mow first time ,took blade off, put deck on ,started tractor blades engaged,checked switch ,ok,thinking something rusted up overwinter,do I need to take clutch off and clean it or can u even get it apart to do so?
   / JD345 pro won’t disengage #2
   / JD345 pro won’t disengage #3
Maybe if you run it for a few, the clutch will disengage?
   / JD345 pro won’t disengage #4
Typically, it's the bearings in the clutch are rusted and thus always engaged.
You could try disconnecting the clutch connector at the clutch and then try again. Seems unlikely that the power to the clutch is stuck on. If it was, your battery would be dead the next day.
Richard
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
71063 (A49346)
71063 (A49346)
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
