Jd4230 transmission pump drive shaft
   / Jd4230 transmission pump drive shaft #1
Mal4128
John Deere 4230
Tractor stopped locked up. Lifted cab and rocker shaft hex transmission pump drive twisted like cork screw. Brought new one and pump.
Shaft slipped in past bush but can’t get in back crankshaft. Trying not split tractor. Can it be done or is bushing stuffed.
   / Jd4230 transmission pump drive shaft #2
Unclear on exactly which shaft you are talking about on a 4230. There is a quad range and synchro range transmission available for that model -no hydrostatic.
The transmission oil pump driveshaft doesn't appear to interface with the engine crankshaft.
Standard pump:
Increased capacity pump:
Maybe you can clarify & we can try to help you out
FYI 4230 is a 1970s row crop 110hp. Were you meaning a 4320 compact?
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2014 UTILITY DRY VAN TRAILER (A51222)
2014 UTILITY DRY...
Stump Grab Bucket (A50322)
Stump Grab Bucket...
2020 KUBOTA RTV...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2018 INTERNATIONAL...
90018 (A48082)
90018 (A48082)
