JD4300 gas and temp gauge not working
   / JD4300 gas and temp gauge not working #1
MACrook
2000 Farmtrac 320 DTC
JD 4300 gas gauge is pegged and so is temp gauge, but rpms work and hour meter. Is it most likely the sending units on gas and temp or the cluster. I understand the cluster for these models is finicky and has known issues. TIA
   / JD4300 gas and temp gauge not working #2
Try to score an electrical schematic for your tractor. Some vehicles use a separate lower voltage instrument regulator for the fuel and temperature gauges. It is about five volts. If it's shorted internally that could certain cause needles to peg.
   / JD4300 gas and temp gauge not working #3
Typical of a lot of gauge systems is for them to go full scale (pegged) if there is an open circuit between gauge mechanism and its sender.... You need to trace wiring from dash panel to sender to see if there is a disconnect or loose or dirty plug/socket.....
2019 Caterpillar 315FL (A44501)
2019 Caterpillar...
New/Unused Pallet of 22 Straps (A44391)
New/Unused Pallet...
2007 John Deere 990 (A44501)
2007 John Deere...
2007 Kubota B21 (A44501)
2007 Kubota B21...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A44391)
2013 International...
2020 CAT 239D3 Skid Steer (A44391)
2020 CAT 239D3...
