JD750 dozer, blade tilts left and dozer stops
   / JD750 dozer, blade tilts left and dozer stops #1
johndeere2210
Nebraska
John Deere 2210
I have a friend that has an older JD 750 dozer. When he tilts the blade to the left the forward movement of the dozer stops. This is a hydrostatic transmission. As soon as he tilts the blade to the right, it will start moving again. He can raise and lower the blade and it does not affect anything, just when he tilts the blade left. Any ideas where to start? Thanks. /forums/images/graemlins/confused.gif
   / JD750 dozer, blade tilts left and dozer stops #2
Just a guess, but check and see if the blade frame is flexing. It might be pinching a return line, starving the transmission of fluid. If the blade frame is flexing, check for a broken mount or weld close to the attach point. As I said this is a wild guess and without examining the dozer there is not much to go on.
Fork Attachment for Wheel Loader (A46443)
Fork Attachment...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
84in Bucket (A47809)
John Deere 72in Grapple (A47809)
John Deere 72in...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A45676)
1993 INTERNATIONAL...
14-17.5 Tires (set 4) (A47809)
14-17.5 Tires (set...
